flyweed wrote:
Yes, I am actually a lighting designer in a theatre..so I know about color mixing with light...I just got some fairly expensive LED theatre lights that have RGB leds, but ALSO have a white led and an Amber LED, so the units are (RGBAW) and this allows for you to actually create warmer or cooler "whites" based on how you dim other LED's in the unit....I guess my main question is, can you create a bit of a warmer white with the dimmer functions on the remote??? I know that just using R,G,B together creates a fairly "cool, bluish" light, and just wondering what sort of capabilities the remote gives you for dimming.
Thanks for your help
Dan
There is 4 dimmer settings, it gets quite dim but it is still a blueish white.
