I have a fully operational LED Light strip now installed on my TT.. I used commercial 1/2" 3-m trim tape on the awning rail and then stuck the 3-m tape that came attached to the LED strip to the trim tape.. It is solid.. NOW the DW wants a strip under our patio cover on the house.. I am reluctant to use the same mounting method (3M trim tape + 3M tape on light strip) that I used on the TT because the additional 3M trim tape is black and would stand out against a white patio cover. IN YOUR OPINION, would just using the 3M tape that came on the LED strip work OK on a metal patio caver taht is stationary and not subject to the same conditions found on an RV?
