DutchmenSport
Jul 12, 2016Explorer
Agree with every one else, the awning has slid in the track. Just slide the awning one way or the other in the track until it rolls square again. Easy fix.
Beware! Once they start slipping around like that, they continue to slip around. So once you get it back square again, use a permanent marker and mark the tube (both ends) exactly where the fabric is, so when it slides again, you can just tug it back to that same spot. Do both ends, because when the fabric moves, it most likely will rub off the marker ink. You can also get a visual inspection before rolling it up every time this way too.
44,071 PostsLatest Activity: Aug 23, 2026
