Hi All.
Thanks again for the assistance with my question regarding the hubs and axles on my camper. As promised, here is an update.
After declining the axle replacement, I was charged significantly over the quoted price for the repack to get my trailer out of the shop. They said the extra was for shop supplies like rags and protective gear along with four bearing seals.
I took the advice of the group and got a second opinion. Interestingly, they found that the repack had not been performed properly. The bearings had not been cleaned and there were two types of grease visible. And they found that the axles were in good shape - no replacement needed.
I had put up the first pictures on my travel web site. I updated that post with pictures of the repack after the first shop completed their work and the repack after the second shop. I tried to capture some lessons learned from this experience.
If you want to see the additional pictures, they are at
Hub Axle QuestionThanks again.
