scottykrug's avatar
scottykrug
Axle flip question for those who have done it.
After reading past posts on flipping axles and discussing it with the DW, we have decided to go this direction. We (the DW ;) currently has to run along side) have to place 2x12s under the wheels to get our rig over a low spot in our back yard. The spare drags in the gravel which is a good thing as IT protects the black water plumbing but not good for the tire.
My question...... as I will be removing bolts from the suspension is there anything else I should need to replace? Some background on that question... this spring I repacked the bearings/adjusted the brakes. In prep, I ordered new seals and had a fresh pile of cotter pins only to find out that lippert uses this weird flat washer with a tang to lock the castle nut (impossible to find in town). Trying to avoid this logistical headache.
I would love to replace all the suspension hardware with wet bolts but funding is not in the works (have my own personal sequester going). Are there any commonly replaceable items that will need to be changed out during this process? Just trying to get stuff in hand before work commences. Will be ordering the 3" kit from Dexter and will have plenty of cribbing to support the frame of the trailer.
Thank you in advance.
Scooter
