BarneyS
Jun 08, 2013Nomad
If you are not going to replace the bolts with a wet bolt kit, you should at the least replace the plastic bushings in the spring eyes and equalizer hangers. Those things wear out very quickly. Spring bushings.
Also take a good look at the shackles as they often have the bolt holes elongated and need replacing. Shackle links and bolts.
If you could afford it, now would be the best time to upgrade your suspension using a kit like this one.
An even better conversion would be this one. You can see a complete installation by both myself and former TT forum moderator LAdams here.
Good luck. :)
Barney
Good luck. :)
Barney
44,068 PostsLatest Activity: Jun 27, 2026
