kcgaz
Dec 31, 2021Explorer
Axle Question
The bearings on the slide side of our trailer overheated and damaged the spindle. I purchased a replacement axle and installed it, but the new axle is much more cambered than the old axle. I know th...
kcgaz wrote:Have you weighed it? All of your symptoms from the bearing failure to the no cambered axles, point to overloading at some point.
Yes, both axles are 3500 lbs. and the arch on the new axle is high and in the center. I only had to replace one and the old axle does not have any arch. Is it possible that the arch has flattened out that much or do they sell straight axles?
