alaskadoug's avatar
alaskadoug
axle rating vs GVWR
The specs for a 2019 Lance 1575 says that the axle (single) is rated for 2530 pounds, The GVWR for the trailer says 3700 pounds. If I understand correctly you should not exceed the axle rating. What am I missing?
  • ScottG wrote:
    Simply, you're missing the weight that is on the tongue.
    Tongue weight was my first thought as well. But that would be an 1,170 lb tongue weight on a 20 foot long single axle trailer. That's about a 30 percent tongue weight. To the OP. The numbers really don't add up. I would call Lance directly and ask them.
    661.941.9250 Customer service, or 661.941.9255 presales questions.
    Lance
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    valhalla360 wrote:
    You are mixing up different numbers. I checked Lances website:
    Ratings:
    GVWR = 3700
    GAWR = Not Listed on their website but probably 3500lb as they won't make a custom axle for a travel trailer. You get the GVWR when you add the hitch weight.
    Empty Weights as it comes from the dealer:
    Unloaded Axle Weight = 2530
    Unloaded Hitch Weight = 245
    Unloaded Total Weight = 2775 (2530+245)
    So you have 925lb of cargo capacity before hitting the GVWR
    Of course this is all per the design calculations, so it might be off by a bit in real life.
    carefull, it may have a 3500lb axle but still could have a lower axle weight rating driven by the tire capacity. Rating will be the lower of either the axle or tire capacity.
  • Fooling with numbers to make a single axle trailer seem safe, adequate for your needs.
    Add water, batteries, propane and your stuff you’ll be over max TT weight.
  • Thanks for looking it up Valhalla. Sure beats guessing.
  • You are mixing up different numbers. I checked Lances website:
    Ratings:
    GVWR = 3700
    TW.
    Though it is not normal for the difference to be that high. It is likely a misprint, and the axle is likely the common 3500# that most TTs get.
    I would contact Lance for clarification.
