JIMNLIN wrote:
boingram wrote:
Buying a 2015 gmc denali 3500 srw crew...door plate has rear axle rating at 7050...can't find out how much of the truck wt is on rear axle...can't weight it till I buy it...is there a rule of thumb for this...duramax...thx..bo
Use this 2014 CLICKY LINK from GM. The feature doesn't come up on the 2015 models yet. It gives each individual trucks front and rear axle weights with the options you choose.
Simply click on "models and options weights" and then "weight calculator". This will get you close to your trucks as shipped weights. This doesn't take into account other necessary "junk" we put in our trucks.
Many one ton SRW trucks rear axle may weigh in the 2900-3100 lb range which leaves in the 4000 lb range for a payload.
Play around with the calculator. Wish Ford and Dodge had this feature for finding actual weights
My 1975 Ford Supercab came with a brochure listing all the possible engine combinations, and front and rear axle weight of a 'base truck'.
Then it had option weights too. So a second battery would add 65 pounds to the front axle and take away 7 from the rear axle. A second fuel tank would add 65 pounds to the front axle and 85 pounds to the rear axle. It was a basic approach to the same problem. It took me about 10 minutes to figure out my weights for my truck.
So the information is out there. You might try looking at the towing guide, and see if they list 'camper weight capacity' or maximum cargo rating.
Your rear axle might be able to support 7,000 pounds safely, however the rest of the truck is heavy too, and you can not load the rear axle to it's max rating without being well over the GVWR for a truck. The front axle weight rating might be say 5,000 pounds, and yet your GVWR could be only 11,000 pounds.
You can normally expect a diesel to have around 4,000 pounds on the front axle and 3,000 on the rear. However in the recently published test of a dually GM crewcab truck, the curb weight was around 8,800 pounds! That is pretty heavy.
Good luck!
Fred.
