Devocamper's avatar
Devocamper
Axle ratings where is the weak link?
I keep being told my current truck an 07 Chevy diesel 4x4 DRW LB EXT CAB can handle the triple slide TC's on the market today with some suspension upgrades but it has some pretty low ratings as it sits stock. I may be wrong but I thing I have the AAM 11.5 axle in 07 and the DRW gives me over 13000 in tire capacity , I have read that this axle is rated higher than the GM rating of 8200 by the axle manufacturer, (current gvwr rating of 11400) so why did GM only rate the axle at 8200 lbs and where is the weak point after the aftermarket suspension upgrades ?
Thanks aging for the help , this is a learning process and the help is appreciated
Mike
  • Springs, tires, wheels all play into the ratings game that manufacturers use. As does the frame. You have a dually, so I would not hesitate to load a 9-1/2 foot camper, maybe even a 10 footer. But more? I personally would not.
