boosTT
Mar 08, 2021Explorer
Axle Service
I have a 2005 19' Keystone tandem axle travel trailer and (yes I know) never serviced the axles. I pumped some grease into the zerks every few years, but haven't repacked the bearings or adjusted the ...
Gdetrailer wrote:
Man, I am glad I don't live where you do.
You can buy complete brake/backing plate assy's in left and right pairs for $95 HERE
Two axles takes two sets of the above so $190 plus shipping for all four wheels.
About $100 per drum (which gives you brand new bearings and seals) so four drums = $400 plus shipping..
So, to fully refresh all brakes, bearings and drums we are talking $600 plus shipping..
To replace all parts should take no more than 15 minutes per wheel just removing and slapping on all new parts..
Say 1 hr of labor at $150 per hr..
Most places do not "double" the cost of materials, more like adding about 25% on top of materials so call it $750 in materials and $150 in labor or $900 for all four wheels out the door cost..
However, I seriously doubt that full on replacement of brakes and drums will be needed.. Myself, I had to replace the backing plates a few yrs ago on a 30+ yr old TT and they WERE the ORIGINAL BRAKES!
I suspect it will be more like just check and adjust the brakes and clean and repack the bearings so in reality, the only "parts" would be needed is maybe $40 in new seals and a few scoops of grease.. maybe 1-2 hrs of labor (2hrs if they are padding the bill)..
Many auto repair shops typically charge less than $100 per wheel to "service" the brakes and sometimes you can catch a deal at $40 per wheel if you shop around..
Myself, it is an easy thing to do so I pull, check and adjust as needed instead of paying a mechanic..
