My word, more than a thousand dollars!? Look, I have a 2006 Airstream and I take mine into the Airstream dealer. Most of you are probably thinking that they must charge an arm and a leg for service. Not true. I have had this trailer since 2009 and always have the dealership work on it. To "service" an axle means to take off the wheels, repack the bearings, check the condition of the magnets and adjust the brakes if needed. They also told me that I should do this every 10K miles. Go by mileage and not time. Service is just this. If you need new brakes or new axles, then lots of money makes more sense. Last time it was about $100 per axle. I think it actually came in a tad under that. Will be due next year...probably will be more.
