Lynnmor wrote:
I would replace the axles with 6000 lb beams. I don't like to have so little margin and the manufactures rating is probably for ideal conditions. If all of your brake parts are good, just use them and only buy the tubes. Stronger springs can cause a harsher ride, if they still have a good arch and the leaves are tight together then you may be OK. I have no experience with the TK axles. Hopefully the trailer is level while being towed and not be part of the problem.
Great, thanks for the input. Yes trailer is dead level when being towed so I don't think that is the issue. I think it should have had 6k axles to begin with. I will research just the tubes vs replacing the entire thing with new hubs, breaks, bearings, etc. Looks like the whole assembly is an easy install but obviously more expensive.
