pjay9's avatar
pjay9
Back end rot
I am starting to do the mods i have been thinking about and found rot...not expected...not surprised! Lance 1161 aft outside hatch under the ladder. It looked like it was dry and ship shape. I stred my truck chains in there and never EVER put away wet chains just so I wouldn't start any water issues.
The mod is to eliminate the outside hatch and make another cabinet inside for shoes at the door. I sawed out the inside in prep for the new door. I cleaned the inside and I detected a damp order. The floor covering had raised up at the seam, pushed on it an it was soft. Pulled it off and the floor OSB was damp, soft and flaking.
I examined the space and cannot see any telltail entry points for the water. The hact was actually stuck around its seal as I hardly ever access this cubby...so I just don't know! I stopped that mod as that area will be addressed during the rebuild.
So if you have one of these hatches go have a look! I'll try images later post.
  • pjay9 wrote:
    Could be the joint where the bumper is attached!
    Yep, that seam above the tail lights looks very suspect. Put a trickling hose on that seam and see if you get intrusion.
  • Super_Dave wrote:
    Could the leak be from the inside and just coincidently be in that area?
    Don't see how!
  • Could the leak be from the inside and just coincidently be in that area?
