Lantley wrote:
Many claim that diesels have higher maintenance cost and are complex as though gassers are foolproof with zero mechanical issues.
While I can agree diesels have become more complex, gasser are not immune from complexity. Maintenance cost are basically a wash.
When it comes to towing the equation becomes do you want the most economical method/tool or do you want the tool that delivers the better performance.
If your goal is to save $$$ at purchase time a gasser will always win, If performance is your goal a diesel will come out on top.
Keep in mind gasser savings is significant when you originally buy, but there is minimal savings from that point forward, once you begin to tow with your truck.
Back in the early days of emission controls on gas engines, they worked to clean the exhaust after combustion. This caused loss of performance and increase in fuel consumption. But in short time they started to clean the burn. Look at the numbers, if you can figure out how big a 350 CID small block is in todays numbers. My 73 Nova, would run about 8MPG 350 in 72 half ton, with nothing required but PCV, near 16. Working everyday loaded or overloaded 100%, of the time, the 71 F350 ran near 12.
So for over 25 years, gas engine emission controls have had bugs worked out. Maybe within the next few years they will work to clean the burn, instead of clean the exhaust on diesels. A few years later, the value of diesel powered pickups will be real.
rhagfo wrote:
Well 6 mpg, compared to 10 to 12 mpg pulling the same load, that is as much as 100% better fuel mileage.
So 1,000 miles of towing, at 6 mpg would be 166.7 gallons, at 12 mpg would be 83.3 gallons. then at $3.50 per gallon 166.7 gallons would be $583.45, at 12 mpg $291.55 difference of $291.90 now the $10,000 of difference in cost for a diesel. $10,000 divided by 291.90 equals 34.25, or break even in 34,250 miles of towing.
On a side note Msmith1.wa, states Tacoma, Wa. as home so those fuel prices are true, gas and diesel in the PNW have been neck and neck for the last several years.
How many miles does the average RVer tow in a year? At 5,000 miles of
towing per year, your looking at over 6 years. Now when you look at RVs on the highway it doesn't look like most keep their pickups that long.
