BenK
May 03, 2018Explorer
4x4 "LOCK" is designed for use on low traction surfaces. Unlocked is okay for pavement (good traction), as the third member is an open diff, whereas LOCKed turns that third member (diff) into a locker with NO slippage/or RPM differential between front and rear drive shafts
If you have 'full time', 'AWD', or any of the OEM offerings designed to be used on pavement, sure thing...drop it into 4x4 *LOW* and go do it.
Most 4x4's today no longer have manual hubs. The reduction in cost has them integrated into the whole front suspension system. Most are then are engaged with the diff 100% of the time and the locking mechanism no longer at the hub, but inside the diff or at the Xfr Case
"Crow Hop" has HUGE amounts of built up energy twisting the drive lines until there is so much wound up, it breaks the tires loose
All because the four tires takes a different arc during any off center movement. The more off center (think steering wheel all the way over to the bump stop) will have those four tires take even larger differences in arc
Here is a thread on this and will post the images from that post for those who don't jump over to read that old thread. There are several other links that explain this in more detail for those who wish to read up on this
Accidentally Towed 100 Miles In 4WD, Posted: 07/06/10 11:44am
The four different arcs each tires take on a turn
This is a broken transfer case. Not just the Xfr Case can break or be warped, but U-Joints, drive shafts, etc can and will bend/break
44,066 PostsLatest Activity: Jul 25, 2018
