SideHillSoup
Nov 15, 2017Explorer
Hi
I ordered my camera from Camera Source and installed in on a bracket I made and attached onto the ladder of my Northern Lite 8-11.
Ram Cam
They didn't list a plug and play camera for my 2017 GMC 3500, so I sent them a note and quickly got a reply of the model of camera to order.
It is a plug and play camera that when I removed my tailgate to load the camper, the camera plugged right into my GMC camera wiring harness under the bed of the truck, and it works great.
I ordered mine with a 16' cord which leaves me a little coil of cord when it is all hooked up that I just laid in the spare tire under the bed of the truck.
I also used a 4' section of clear 1" hose to slide the cable through so rocks etc, don't damage the camera cable that is strung out under the camper. The cord with the plugs on the end just fit inside the hose, where I didn't have to cut slit in the entire length of the hose to get the cable inside. I did take the cable to the hardwear store to find the right size of hose.
Sorry can't help you guys with the back up sensor, however my wife does a great job of backing me up, but you can't have her... ( grin)
Hope this helps.
Soup.
Ram Cam
Hope this helps.
Soup.
44,071 PostsLatest Activity: Aug 30, 2026
