cubbear's avatar
cubbear
backup camera
had to remove tailgate with backup camera in it is there anyway to remove camera from tailgate in install on camper? it is a 2015 F 350 DRW PSD Thank you
  • brholt wrote:
    This was my "temporary" solution (still using). Note some pretty good ideas in the comments
    Ford Backup camera
    That's pretty cool. What does the picture look like on the dashboard screen?
    Also, what circuit needs to be tapped to wire in one of the up fitters to trigger the camera in "on-demand" mode?
    Thanks,
    Joe
  • Thanks Joe. I will be building one of these camera setups for my rig this winter.
  • Here's a few photos describing my setup.
    First, a little background: My truck is a 2014 with the Lariat package, which means I have the factory camera in the tailgate which displays on the nav/touchscreen in the middle o' the dash when the truck is in reverse. When the slide-in camper is on, the tailgate is off, so what I wanted to do is put a camera on the back of the camper, and wire it into the OEM system so it'll work the same way. I did not want to disassemble the tailgate to get the camera out of that.
    First thing I did was to gather up a few cameras to test, I wanted the best resolution I could get in both daylight and nighttime scenarios. Basically, in the 12V backup camera world you have four choices; Infrared (electronically enhances low light images), non-infrared (requires a good light source to use at night), guidelines and no guidelines.
    Here is my test setup. I tested three cameras both with infrared and without, and with lines and without. The below photo shows that for testing I just taped the cameras to the camper so I could move them around establishing the best angle.
    I wanted a bird's eye view, cameras with the built-in guidelines work best at bumper level:
    I wasn't too thrilled with the nighttime resolution of the cameras with the infrared LEDs, so instead I wired up a couple of cheapo LED floodlights and settled on the smallest (and cheapest) camera as it has the best resolution under all light conditions. The camera is so light that I just used double-sided tape to mount it under the center clearance light above the door. You can easily bend the tab it mounts to to adjust the angle.
    Please forgive the mess of wires by the floodlights, my original plan was to mount them on all the corners of the camper but the sheer amount of light they throw out means I can mount them on the ladder where they're out of the way and still not miss anything.
    I wrapped up all the wires (floodlights, camera, antenna) in black split tubing and followed the ladder down to the corner of the camper and under.
    For the camera I used a factory connector and just plugged it right in under the bed where it would if the tailgate was on.
    The Results:
    Parts Needed:
    From Amazon: Esky EC170-06 Smallest HD Color CCD Waterproof Vehicle Car Rear View Backup Camera, 170 Degree Viewing Angle Rearview $20
    Tuff LED Lights 2 X 4" Inch Round 27watt LED Work Lamp Light 1550 Lumen, Off Road, Atv, Utv, Polaris Ranger $49 (pair)
    From Ford: Tailgate wiring assembly DC3Z-14A412-A $9
    Hopefully that helps,
    -Joe
  • With Ford it is inexpensive to buy the wiring loom to connect a backup camera. The cameras are cheap, it is the hookup that can be involved. With GM they will only sell the entire assembly for around $400.
    I did not want a backup camera that only worked when the truck was in reverse. I wired a camera to the running lights so I could turn the camera on while driving down the road. The backup camera on my truck is nearly useless when the sun is behind the truck. The aftermarket ones have sun shades and work much better and there are combo units with two cameras in a single mount so you can have one directed behind the camper and the other pointing down at the hitch.
    I went with a Garmin 760 LMT GPS with its BP20 camera so as to have only the one display on the dash and easily switch back and forth between GPS mode and camera display mode.
    Other places for video gear are tadibrothers.com and cubbycam.com. There are LCD displays that will work with up to 6 cameras so you can have side cameras as well as front and rear facing ones.
  • If it's a Ford truck you can get the a cable, camera and bezel from the parts department. It will require that you splice in an additional length of wire so that it will extend the the rear of the camper.
    This method will allow you to simply plug into the existing camera plug under the tailgate.
    But yes, you should provide more information here about the year, make and model of your truck.
    As an option, if you want to go inexpensive. I have one & it works great.
    Has "night vision"
    Yada Back-up Camera $55
  • Truck year/model? I was thinking of doing the same but bought a second OEM camera and cable instead because I want to use the truck without the camper as well and have found the tailgate cam quite useful. You could also find tailgate with camera and cable at a wrecker.
