oyarsa's avatar
oyarsa
Backup Camera
Any recommendations for a backup camera for the back of our RV? I'm looking for an easy to install (preferably no drilling), relatively cheap (150 or so) method. If it stays on while driving, that's great but not necessary. I also don't particularly care about the display quality...
I've tried looking at Amazon, reading reviews, searching this forum, etc., but I'm no closer to finding one I like...
  • oyarsa wrote:
    Thanks for the suggestion. I'm not having much luck with the first item. Maybe it's unavailable now. Sounds like that might be a good way to do it...just run a long cable...
    Yes, better than wireless. You'll need two cables-one from the camera to your hitch nd another from the hitch to the monitor in the truck. You separate the two when unloading the trailer.
  • Thanks for the suggestion. I'm not having much luck with the first item. Maybe it's unavailable now. Sounds like that might be a good way to do it...just run a long cable...
  • Here is what I got from Amazon, about $80. I attach the camera to my rear ladder then run the wire under the trailer (zip tied) to the front of my 5th wheel to the pin. From there the wire goes to my back door and into the cab. I use the same wire and monitor for my truck camper but just bought a camera for the TC:
    ODGear Backup Camera and Monitor Kit For Car ,4.3'' LCD Car Rear View Monitor Night Vision Reverse Backup Camera Waterproof https://www.amazon.com/dp/B01M6UIS25/ref=cm_sw_r_cp_api_ORreAbCXADT5Q
    REARMASTER 12V Cigarette Lighter Power Supply Kit for Car rear view camera and Monitor with RCA connection https://www.amazon.com/dp/B01N2T53ZR/ref=cm_sw_r_cp_api_1SreAbDSDBD4W
    ATian Waterproof 18 LED Car Rear View Night Vision Reverse Video Backup Parking Camera Black Color https://www.amazon.com/dp/B015J0CGIY/ref=cm_sw_r_cp_api_BTreAb7ZJD0MG
    RCA Plug DC 2.1 5.5 MM Power Video AV Extension Cable for CCTV Security Car Tuck Bus Trailer Reverse Parking Reverse Camera 15 Meters 50ft by HitCar https://www.amazon.com/dp/B00DVZYCZA?ref=yo_pop_ma_swf
