docnascar's avatar
docnascar
backup reverse lights on trailer?
For those times where you get to the campsite late and its very dark out, does anyone use additional running lights on the sides and/or rear of the trailer?
I was thinking about adding something, but I don't want to spend alot of money. Then again, I don't want something that is not bright enough to see where I'm going while backing up using my mirrors. I'm always leary of buying lights when I don't know how bright they really are.
What's the preferred way to hook them up? Through the wiring harness for access from the TV or put a switch in the trailer and connect it to the battery?
Anyone do something similar?
  • I just finished this LED light strip install down both sides of the Sonic:
    I don't know if they will help when backing up, but they sure do help with seeing whats around the camper! Mounted the controllers in the pass through, drilled a hole in the front wall right where all the factory wires came in. They of course do 256 colors, flash, rotate through all the colors, ect. This pic is in WHITE mode...
  • I added a reverse/accessory light to the rear of the trailer because in find myself getting to the camp in the evening on Fridays, or bringing it back to my storage area in the evening.
    I have it on a separate switch not automatic.
    It's hard to tell, but it puts out a lot of usable light.
    I also have lights under the trailer on a separate switch:
    And I have lights on the truck (these are the same as the one on the trailer, just black):
    They all come in handy.
    Happy trails!
    Joe Zeppe
  • Nice setup. I've thought about mounting a wheel well light on our trailer as well. I think lighting up the wheels is more helpfil than the rear of the trailer especially if you have a spotter.
    Dakar Dad wrote:
    I purchased 10 lights on eBay for a killer price. (Search for 2x 18W Cree LED Work Light Bar Flood Beam 4WD Offroad Vehicle Driving Lamp) Now I find they are 1/3 the price now.
    I use the reverse light wire from the trailer plug to energize a relay and I let the trailer power the lights mounted on the trailer.out my tires while driving.
    I mounted two of them under my truck bumper, two over the tires and two on the back of the trailer with them facing outwards a bit.
  • mh, Look at the top 2 topics in the "Do It Yourself Modifications and Upgrades (DIY)" forum for how to post pictures.
