DavidP
Sep 08, 2016Explorer
I would deal with it at home where you can check it out thoroughly. Take the tire to a shop and have them flip it so the worn side is on the outside. As long as it is not to bad and there is tread left this would get you home. If you have one you could also mount the spare as well. Once home you can then check the bearing carefully and if the axle is bent have a good shop align it.
