DavidP
Sep 09, 2016Explorer
trail-explorer wrote:DavidP wrote:
Take the tire to a shop and have them flip it so the worn side is on the outside.
THe tire should be replaced because if it's worn excessively, it's a ticking time-bomb waiting to blow.
Hey trail explorer, you’re just like the media and take a quote right out of context. If you’re going to quote me use the entire quote.
I wrote: “I would deal with it at home where you can check it out thoroughly. Take the tire to a shop and have them flip it so the worn side is on the outside. As long as it is not too bad and there is tread left this would get you home. If you have one you could also mount the spare as well. Once home you can then check the bearing carefully and if the axle is bent have a good shop align it.”
Neither of us have seen the tire. It may be a “ticking time-bomb” or perfectly safe to flip to get home with if not badly worn inside.
44,071 PostsLatest Activity: Sep 17, 2026
