myredracer
Oct 25, 2017Explorer II
plasticmaster wrote:
Has anyone used the Bal lock arm stabilizer bars with these jacks. How well did it help to stabilize the camper?
You need stabilizer "struts" for these incorrectly termed electric "stabilizer" jacks. :R The strut things work great! My DW can tell when I haven't tightened them up when the jacks are down. I only mounted a pair on the rear because I don't think a second up front will help as much for us. The front of a TT also has the tongue jack which provides some degree of vertical stabilizing that helps a bit. Nice thing about the BAL struts is you can buy just a pair of them.
I mounted the upper ends of the struts to the underside of the bumper and that way they also give some fore/aft reduction in movement in addition to vertical and lateral. I used a piece of 2x2 steel tubing and bolted that to the bumper. Not an easy job to fish the bolts 4' inside the bumper.
While doing this project, I mounted a piece of 8" x 8" x 3/4" HDPE to the stab. jack feet. This adds more stability when jacks are down and don't have to bother with planks or "lego" blocks. I mounted the lower end of the struts to the foot pads because it's more stable that way than using the horizontal bolts. If you mount to the actual stab. jack, I found that there was too much play.
Note well that if using any brand of stabilizer strut, you must get Lippert's #314597 "jack adapter kit" as in the photo below. If you don't use these, the strut arms will interfere with the stab. jacks when in the retracted position (the strengthening pieces at a 45 degree angle).
I tried a set of the aluminum stacker jacks with the BAL struts in place and found that the stacker jacks did not make a noticeable improvement and got rid of them on CL. (The lego blocks are only under the stab. jack pads to see if having the pads higher off the ground would help - it didn't.)
How well the BAL braces will work will depend partly on how strong your frame is and it's length. In our case, our TT has a very strong frame (8" tall I-beams) and is 29' long overall. Some frames flex a lot and sometimes floors are weak which adds to sensation of movement. You might find it helps to use a pair of jack just ahead of the axles. If you have surplus $$ to spend, go ahead and add another pair of the BAL braces to the front jacks. If you do, you'll find it's harder to reach the tightening bolts tho. BAL X-chocks do a pretty good job of reducing fore/aft movement and should get a set if you don't have them already. For even more reduction in movement, Torklift's Glowsteps cut motion from walking in/out quite a bit.
If you ever want to see how poor a job the electric stab jacks do of "stabilizing", go watch the jacks move around when someone goes up and down your entry steps. They're a poor design by Lippert. They could build them better but there'd be no benefit to Lippert. I know one forum member who added some strengthening to his. I believe the electric stab jacks UF sells are the same ones as Lippert.
