LarryJM
Oct 26, 2017Explorer II
plasticmaster wrote:
I've thought about this some more. Fuses blow and circuit breakers trip to prevent damage from occurring. Sometimes while hooked up to 30A, my wife will forget and turn on the hairdryer while the air conditioning is running. Within a few seconds, the breaker trips. I'm glad my camper has circuit breakers or else serious damage could occur. Why would I purposely push something to the point of tripping the circuit breaker every time I use it? That just doesn't sound good to me. From my own experience on my concrete driveway, I know that tightening for a couple seconds like in the Lippert manual leaves me a very unsteady camper. Tightening until the motor starts groaning and straining results in the same. I don't think any consumer should have to push a product until the breaker trips in order for it to work effectively. This is why I've ordered 4 manual scissor jacks and will be installing them soon. That's what I used on my previous camper for 8 years. I would hand crank them until they put just a slight pressure on the camper. They provided much more stability than these electric jacks do.
You"re learning, but not quite there yet IMO:B;)
below is a post I made several years ago and have successfully used it now on two trailers going back to 1981:
HEREare the jacks I purchased.
Jacks Method: The whole "SECRET" here is in the where and how you put and set these 4 jack stands. You might have to do a little experimenting based on the specifics of your trailer and it's living layout and who uses it. The first secret is to get the support much closer to the suspension points and I have found based on our 31'+ TT that about 4 to 6 ft in front and to the rear of each axle is a good target area. The second just as important step is in how you set these jack stands up. This is where that electric tongue jack is a life saver. You need to start with the trailer about 1" down by the tongue and put the rear jack stand in and "SNUG THEM UP" hand tight. Then you raise the tongue of the trailer about 2" "TONGUE HIGH" and put in the front jack stands and again "SNUG THEM UP" hand tight. Then you lower the tongue till all weight is off and then raise it again to just get a good pressure on it. Some will caution about "tweaking" the frame when putting pressure on these jack stands, but IMO that just is not an issue since we are only now talking about most support being across a span of between 8 and 12 ft and to the close to 30' if trying to support the entire span of the trailer on the existing stabilizer jacks. Also, you're not "LIFTING" the wheels off the ground you just need to get a real good upward force on the frame at those points. I actually measured the force when I dialed in my new system with my Sherline tongue scale and had around 400lbs of force on each jackstand. Now if once you find the best new locations for these jackstands you can remove and discard the old front jacks and depending on how well the overall stability is from movement in the rear of the trailer you might be able to also remove those rear stab jacks or if needed deploy them to just take out the "FRAME FLEX" component from that 10' or so span between your new rear jack stands and the actual rear of the trailer. As a consideration you might even store the removed jacks and put them back on when you get rid of the trailer so the next clueless owner won't feel he's not getting what is generally installed on trailers now days.
Before naysayer huntingdog chimes in about the garbage of having to crawl around, etc., etc. I have developed a procedure which avoids all this and has several side benefits such as a quite "potty stop" necessity to pull out the trailer steps and to work around your sewer connections and other things left to the believers to develop for themselves.
Note there have been a handfull of believers in this method and properly done all have endorsed it a one if not the best alternative to stabilizing longer trailers (i.e. those 30' and longer).
BTW I was in CW several days ago and saw an upgraded version of the above shown jackstands that look like they might even be a better alternative, but IIRC a set of 4 is close to $100. These look more like a traditional car jackstand and incorporate a screw portion for fine tuning and height adjustment along with a better footprint. However I'm still using the same ones for the last 36 years and they have never had an issue or required once ounce of maintenance.
Larry
