Ron35816 wrote:
I am in the process of replacing the original tires on my travel trailer and was wondering should I have them balanced or not? The ones on the TT are not balanced. Also what is the torque on the lug nuts? Any help would be appreciated.
Yes, balance the tires is my suggestion. Imbalance will introduce additional vibration at the resonant speed and you don't want any more vibrations than necessary shaking the TT loose.
As for lug nut torque ... see your manual and if lacking then 100 ft.lbs measured by a torque wrench is good.
