BigToe
Aug 21, 2013Explorer
You may have both problems.
Definitely have the first problem... achieving an accurate and repeatable dynamic balance definitely relies on precisely centering the wheel and tire assembly to the machine.
No. Especially not if the rim is hub-centric, which won't have tapered lug nuts or lug seats.
Ford even recommends Haweka centering devices to be placed on commercial spin balancers for the OEM factory truck, bus, and motorhome wheels that are 19.5" and larger.
The wheel stud centering sleeve kits can help center a wheel on your hub too.
There are also dynamic balancers, by Centramatics or Balance Masters.
Will not just tightening the wheel nuts down in a reasonable pattern hold the wheel onto the mounting plate studs exactly centered?
