Artum_Snowbird
Aug 21, 2013Explorer
Butch50 wrote:
When you put the Visions on your truck did you not change to different lug nuts? The Ford wheels are hub centered but the Visions are lug centered. I got all new lugs with mine when I put them on and they are a tapered lug nut to center the wheel. My stock ones are a lug with an attached washer but again the wheels are hub centered and do not rely on the lugs to properly center them.
Yes, I did put new wheel nuts on. I used Rhino nuts specifically designed for these wheels.
