Lynnmor
Oct 11, 2018Explorer II
hawkeye-08 wrote:
If balanced properly, nothing to lose. For those saying the drums are not balanced, I don't disagree, but why would I add to it with unbalanced tires?
I have a tire/wheel that is unbalanced, I also have a drum that is unbalanced. By orienting the heavy spots opposite each other the assembly needed no weights. In this case, any added weights would have made things worse. Once again, if you are not balancing the assembly you are only doing a feel good thing.
But you are correct, by not checking the balance of the drum you have a better chance of getting a better result and a lesser chance of making it worse. You do have no way of knowing the result.
44,070 PostsLatest Activity: Aug 06, 2026
