Grit dog wrote:
panamacamper1 wrote:
In all the videos I watched it seemed pretty straight forward on removing the hubs, what things were done wrong to have to replace hubs? Being that I am in korea, i wont work on it until I getback in nov unless someone else does the work. So moog expensive, got it. Ill keep lookin
For everyone that chimed in and doubted everything that the OP said could be wrong with the truck, YDHAFC.
Oil pans rusting through on the Cummins are fairly common on trucks in the rust belt.
Front unit bearings are also common around 100-150k mi.
$120 for an oil change may seem steep to you doubters until you go buy everything assuming its a lof service, air filter and fuel filter. Yes I can do a complete service on mine for about $70 in parts and I buy in bulk and oil on sale. Add some markup and 1/2 hr labor, you're well over $100. Wake up, it's 2014 not 1994!
Replacing BOTH unit bearings and not the hubs, although sometimes they are so rusted on they get damaged. Buddy and I fabbed a puller to remove the hubs. It saves the hub. Doing both, figure $300 ea side for parts and 3-4 hrs per side. That's $1200 min at a shop.
Oil pan, the motor needs to be raised up a bit to get the old pan out and new one in. Again $3-400 for pan and gasket and $500 at least in shop labor.
$2100 sounds about right for that work.
Couple tips. How do they know the unit bearings are going bad? Ask your wife if the front end is growling or grinding.
Many a rusted oil pan was fixed semi permanently by draining the oil, cleaning it up, prep the steel and apply some jb weld. Personally I'd do the cheap fix if I was driving the truck but I wouldn't trust not having eyes on it and risk losing the engine from a bad oil leak at the hands of my wife. Your call there. Depends if she can keep an eye on it.
Basically you have 2 common Ram repair items that just popped up.
That said I still wouldn't just trust one shop unless you could verify all the work actually needs done.
Haha, good post! Yep, you are the one with a clue.....lmao.
