I installed the Banks "Git Kit" on my 2000 F250 7.3 diesel, along with the EB. It consisted of the larger intake and exhaust, the high performance turbo wheel, the wastegate actuator, the performance chip, the tranny chip, the high flow muffler and a turbo saver from a different company. I installed most of it myself, some I had done at a shop. I would recommend having the turbo wheel installed at a shop, but you may be handier and more confident than I am. The connection from the EB to the exhaust pipe was a MAJOR pita but doable. It made a huge difference in hp, torque and overall performance. Turbo lag was almost gone. It had less lag than my 2012 Cummins. MPG increase by about 1.5-2, depending on circumstances. The real difference was on long grades and quick acceleration. It no longer felt as if it was restricted and struggling and didn't blow nearly as much smoke as it did before. If you install it in pieces, it doesn't hurt as bad, and I found the sales team very knowledgeable and helpful. All in all, I found it to be a very good investment.
