I breifly thought about painting but too late. Though I think just by design too flimsy with too few screws. Yes as mentioned the housing IMO have top & bottom mounted horz but I assume they are all assembled the same? And one of em is going to be upside down when orienting function? 'course less an issue if sealed...
One was from private party-which is what motivated me, the second- best price I could find was 31.5 shipped thru ebay
Bargman 47-84-410.
Just FYI if looking the 47-84-410 and 42-84-410 are the same (red)led replacement lens. The 42- & 47- refers to packaging. The 42- is hard plastic pkg, the 47- is in a plastic bag. Hence youll see different dimension for product.
While I tend to agree on wire nuts used in automotive use not the best choice by far, especially where wire can move/exposed, these once installed are tucked inside wall fairly snug so no movement. Orientated nuts vertically so no moisture can collect, they replaced crimped on wire nuts. As I may try to come up with something on the B/Us so other than resealing base, ease of removing. Otherwise I generally reach for the soldering iron but RV lights I don't consider permanent. Hmm I did deform the crimp on nuts to inspect wire for corrosion-none, wonder if its the brass bulb in steel socket mounted to aluminum plate mixed with water. ha
