Spyder2U2
May 29, 2014Explorer
Barker Jack Kudos
Just wanted to give BARKER an A for service on my Barker Jack 3500.
I had the switch failure after a few years of use. Jack ran up or down intermitedly. Read a few threads like this one here.
Barker Jack Thread
I decided it was the switch and gave Barker a call. Spoke to Gary and he gave me a few details to check out and to call him back. Pulled the jack apart, ran a few tests, sure enough the switch. Motor and battery were fine. Called Barker back and Gary decided to send me a new switch at no cost. I should have at this point ordered a new plastic housing as mine had discolored (ugly) just to give them some business for the freebie. But I had bought a can of Krylon Pastic Paint to redo it already. (Turned out great)
A few days later popped the switch in and it worked great again. Jack looks new minus the decals. This jack was covered for half it life. This makes a huge difference. Sun damage and water takes it toll on this jack. Get or make a simple cover of some kind. You will be glad you did for the long run.
Again, Barker made this easy to take care of....
Just a few notes.
Used steel wool on the the plastic housing to rough out for paint prep. The area where the decals were applied needed a bit more attention than the rest of the housing. Sun really degrades plastic in SO Cal.
Take pictures with a crappy phone as you go so you can 'remember' where the wires go.
Krylon Pstic Red is basically fluorescent red! Ugh! Went to boring white.
Metion again. Use a cover.
Spyder
Love my Barker Dump Tank too!
Barker Jack Thread
Just a few notes.
Spyder
