Ski_Pro_3
May 05, 2013Explorer
The nice thing about this heater is that it is not an on/off heat. It gets hotter the more difference between the room temp and the thermometer setting. If the room is only a degree cooler, then not much heat. If the room is 3 degrees cooler, then more heat. It will keep the room within .5 degree of set point. It also has a set back of up to 9 degrees. Press a button as you leave for the day or a walk and the thermometer goes to any temperature you set it for either + or - up to 9 degrees, and stay there until you press the button again.
The only thing I DON'T like is there is no on switch. I can't turn it off except for the breaker it's wired to.
44,068 PostsLatest Activity: Jun 10, 2026
