az350x wrote:
Thoughts?
Can't imagine why you'd want to bother with dual 6 volt batteries when you mostly camp on electric sites. I also can't imagine why you'd waste valuable battery reserve on something like making coffee with an electric coffee maker when there are so many other options available that don't require any electrical power at all AND so many other things you do want to keep running that are FAR more important, such as your gas fridge. If single battery reserve over the length of time you expect to camp without power is a concern then why not simply up the size of replacement battery you buy, as an example a Group 31 instead of whatever you had previously. As for a "quiet" genset none of them are really quiet, merely "quieter", and a quieter inverter model won't be inexpensive ... so start saving! ;)
