MartiniSCP
Jan 06, 2018Explorer
Batter and charging system
Hello all.
I've been doing some work on our 99 Dutchmen TT.
I'm doing it after work at the storage facility so I've been using the furnace and lights.
All of the sudden the battery drained to nothing and the truck (Chevy diesel 3/4 ton Silverado) isn't charging it.
Should the truck be able to charge the TT battery while only idling?
Should the truck battery/charging system at idle be able to run all the TT D/C powered components?
When plugged into the TV the running lights on the TT work relative to the TV lights. Turn off the lights on TV and running lights on TT go off simultaneously.
I've been wondering if the plug attached to the TT is maybe needing replacement.
Is this probably evidence of that?
Thanks to all, in advance.
B
B
