Boomerweps wrote:
KeTuanis wrote:
Thank you for your reply. Very helpful. I will check those right away.
And to clarify, the only reason to run the AC is to make sure I am getting a good feed from the RV electrical station, right?
Previous poster meant to check an Alternating Current only device to check your shore power. That could be your Air Conditioning.
Correct. Plug in a lamp, cell phone charger, use the microwave if you have one or even the air conditioner if you'd like ;). Some folks make the mistake that because the lights are on and the fridge runs that the shore power is good.
