KeTuanis's avatar
KeTuanis
BATTERIE/CHARGING ISSUES
Hi guys, I left my trailer plugged into the car tow package overnight(7 prong) and I woke up to dead batteries, both trailer and car.
Even though my trailer was plugged into the 30amp station at the rv park.
Will the inverter not charge the batteries if I leave my trailer plugged in the car?
Help!
  • Thank you for the explanation on the cable. I was wondering what that cable was all about.
    I am away from my trailer for a couple of weeks. I will follow up on all the advice given and let you know if any of it resolved the issue.
    Thank you all for your valuable input!
    Help!
    What TV do you have? I'm curious to know. Don't know about GM or Dodge, but Ford trucks cut the connection between the trailer and the truck if the key for the truck is off. There can't be a parasitic draw from the TV to the trailer.
    When sleeping in a Walmart parking lot while on the road, I leave the trailer plugged into my F150. Never have a problem.
  • Whether to use an inverter or a generator depends on the type of load and how often you will need emergency AC power. Generally, an inverter is more economical power alternative to run items under 1000 watts, suitable for small appliances, TVs, VCRs, DVD players and other low load devices. If you plan to operate a refrigerator, freezer, washer, dryer or well system, then a generator is a better choice. If your planned power consumption exceeds 2000 watts, you should choose a generator, as the draw in the battery will rapidly deplete its power. inverterreview.com
  • I am confused about one thing after reading this thread.
    Is it an INVERTER or a CONVERTER?
    Generally....
    CONVERTER: Converts 120vac to 12vdc
    INVERTER: Converts 12vdc to 120vac
    Some inverters are also inverter/chargers that actually do both functions one at a time as needed.
    Post the model number off the unit or electric panel to know exactly what you have.
    I assume what you have is a converter. BTW some are a lot better than others depending on your style of camping or battery recharging expectations.
