TECMike's avatar
TECMike
Batteries: Marine/RV or Marine?
OK folks, getting time to get another battery to replace my nearly four year old Interstate group 24. Got it at Sams and it has been a good one. But Sams does not sell Interstate any more. But they do sell Energizer which is distributed by Johnson Control. But it is time for a new one to be safe.
Should I get a Marine/RV or a Marine battery? I know we need a good battery for trailer brakes, slides, furnace, lights and other goodies.
Not sure I know the difference between Marine/RV, Marine Battery or Deep cycle. Been reading up on batteries, but it has become confusing to this old Boomer! Thanks in advance
Mike
  • I have a Walmart 110 amp hour battery in my TC right now. I like the 2 year warranty. I think there great. If it fails there is always a walmart around.
  • It all depends on how you use your rig. If you always use it where there is shore power available any battery will do. If you do any dry camping you should get at least a group 27 deep cycle or even better a pair of 6v "golf cart" batteries. The amp hour rating is what you want to look at - the more the better.
  • Hi,
    I would encourage you to increase the amp-hours of capacity and to use a deep cycle battery.
  • If you dry camp you might want to consider going to a G27 battery over a G24.
    Or go off the deep end for 2 - 6 volt batteries.
  • Guess I did not know which type has enough strong enough power for good operation of the slide.
    Any opinions about the Walmart Everstart Maxx or Sams Energizer? The Walmart has a two year free replacement and appears to be their top of the line battery. The Sams Energizer has a tag on it which says it is distributed by Johnson Controls, which I believe also own Interstate. But it is a one year free replacement.
    Thanks in advance for your thoughts and opinions on these two batteries.
  • You may also want to look into getting an deepcycle Marine AGM battery. Many many benefits of AGM over wetcell batteries.
    AGM vs WetCell
    AGM Battery
    WoodGlue
    Mike
    That battery may last another two or three years, if it is still holding a charge now. I would not replace till it goes bad. When I did replace I would get a deep cycle only battery. Maybe the agm type. Those marine/rv batteries only have about 75 amp hours usually and you could get a deep cycle only battery that will have up to 110 amp hours. JMHO
    Mike
    Marine/RV or Marine Battery are the same animal........unless it is a marine starting battery. Marine/RV are deep cycle batteries but are still something of a compromise between a starting battery and a deep cycle. When you're looking for a replacement, compare the amp hour ratings of the batteries you are considering. The Marine/RV battery will also have a cold cranking amp rating (cca) but that is irrelevant to your use of the battery; amp hours is what matters for use as a "house" battery.
    I have two group 27 Interstate Marine/RV batteries on our WhiteHawk. Did a 3 day weekend dry camping with them a couple months back and they were still about 60% capacity when I brought them home and put them on the charger.
