Camper_Jeff___K's avatar
Apr 27, 2013
Batteries replaced for free, 22 months replacement remaining
My two, 1 year old SEARS Platinum PM-1 AGM Group 31 RV/Marine batteries gave out on me after less than a year. Both worked great over last summer but this spring I went out to check everything and they had lost their ability to supply sustained power for long periods of time with only about 5 amps running. They would charge up just fine but could not supply power for more than a couple hours. Took them into SEARS and they put them both on their battery diagnostic machine. The machine charged them for 4 minutes, switched to test mode and immediately registered replace and the result was the same for the second battery. SEARS held up their end and replaced both batteries on the spot free. I installed the new batteries in the TC, checked the gauges and they registered 12.9 volts off the shelf. The solar is hooked back up and the 45 amp Boondocker is charging at 13.2 volts. Going to spend some time working on the camper this weekend and get her ready to head out in a couple weeks. It will be so nice to have full power again.
I will say thanks to a couple companies that have treated us really well with the products we bought from them.
SEARS, Les Schwab, Torklift, Camping World, Costco, Wal-Mart.
  • I'd be a little concerned with the reason why they BOTH failed. The two of them both going down seems a little strange. I guess there could of been a bad batch of batteries but just seems highly unlikey that both would fail unless there is another problem causing it.
  • Always good to hear about good customer service.
    I've been sending more emails lately for both good and bad service.
