brdprey's avatar
brdprey
battery banks
:h
this is for the TT group.
i have been looking to add an extra battery bank to the tub. when we purchased it. it had already been converted from a single 12 to dual 6. yea i know we haven't even gone camping in it yet. i dont like hook ups and usually do this a week at a time.
i usually carry extra batteries in the truck for our pop up.
i was hoping i could get some ideas of where to relocate the bank.
and learn why you chose that location.
plus, i love this place. you guys are very creative and make it worth coming back night after night.
yea im also hoping to see some pics of this as well.
i am hoping to save enough thru the winter and next year to convert to 300 + solar system. the longer we are out the better it is for our sanity.
  • pianotuna wrote:
    No, they don't take a lot longer to charge.
    It depends......mostly upon exactly HOW they are being recharged.
    I am guessing here a bit but how many small travel trailers that come only with a single battery do you know of that come with a 50 amp charger/converter ? My semi-educated guess is somewhere near to none.
    Anyway, I didn't say "a lot" longer. But it could be a lot depending on circumstances.
  • Hi,
    No, they don't take a lot longer to charge. Charging rate at 85% state of charge is about 12.5 amps per 100 amp-hours of storage. So long as there is a 50 amp converter, charging 400 amp-hours to 100% from 85% will take exactly the same amount of time as charging a 100 amp-hour jar.
    In the Op's shoes I'd add both battery capacity and solar.
    Sam Spade wrote:
    While extra batteries supply power longer, they take a correspondingly longer time to recharge too. And there are a few other disadvantages to extra batteries too....as is already being discussed.
  • coolmom42 wrote:
    I would take the money you might spend on extra batteries and invest it in an appropriately sized solar system for your dual 6 V system.
    And even before that, I think he should invest in a good generator.
    (He didn't mention if he has one or not.)
  • I had one of my exterior compartments beefed up for load carrying capacity and added extra batteries there.
    I do have switches so I can use one bank while charging the other.
  • If, and that is a big if, you have the weight capacity on the tongue, just weld a carrier to hold two batteries over the two now on the tongue. Batteries outside a living space are always better. Even AGM manufacturers specify the batteries must be vented to the outside.
  • I would take the money you might spend on extra batteries and invest it in an appropriately sized solar system for your dual 6 V system. Two good 6 V (I'm assuming golf cart, or similar) and an adequate solar system should be enough to carry you for several weeks at a time, unless you have extremely high power needs.
    There are not a lot of places IN a trailer to put batteries. If you go to sealed AGMs then you have more options. But you still have to consider the weight. Somewhere like under a bed or dinette, possibly with reinforcements to the floor or frame, is a reasonable inside location.
    If you don't use sealed batteries, you could weld a support system to the frame to keep them outside.
  • Adding them to the tongue is out for obvious reasons. Is there a storage box in the front? Good place to locate batteries as long as you can vent them outside.
