westend wrote:
The same can happen if there is a short in the battery wiring or internally in a battery, feeding high amperage to the inverter/charger.
Wouldn't a short in the wiring send current to ground? And that same path would be present in an internally shorted battery?
We still don't know the condition of any of the OP's gear as he hasn't replied back and I'd bet he had a communication issue rather than a charging issue. He does not state that his batteries or charger have failed in the past tense. We may never know.
If there is a short in the battery bank it can send current to the inverter. Some use a 300 Amp fuse or breaker on the positive side of the battery bank lead to the inverter/charger to protect against such an occurrences. I am one that is a believer after seeing inverter/chargers destroyed by shorts in batteries.
I would agree in it being a communication issue. Something in the charger did not sense a full charge and continued charging until it fried the batteries, but it can occur either way.
It would be no different than shorting directly across the terminals of a battery even with the ground wire attached. Catastrophic failure.
