azrving
Nov 10, 2015Explorer
rbadger28 wrote:
Am I okay to let the batteries sit dead for a couple weeks and just let them charge when on shore power next?
No. It's the worst thing to do to a battery, well that and not having electrolyte covering the plates. You also need to get a digital volt meter. They are cheap and easy to install. You want your battery voltage to be between 12 and 12. 6 or 12.7 volts all the time. No, it wont kill the battery instantly if it dips to 11.9 or 11.8 but the basic rule I follow is dont go below 12 volts.
I have talked to several people who find this strange. They often think of a battery as being a gas tank like their vehicle and it has full and empty. It is like a gas tank but it's range or band of usable power lies between 12 and 12.6 volts. You could dip to lower voltages but the battery life may be shorter.
Having your battery sucked dead as it has will kill it very soon. If you intentionally wanted to kill your battery the best way to do it would be to put a load on it and come back a couple weeks later to find it flat dead, then partially charge it and do it again. You need to get it fully charged and keep it charged. The final determination is not to charge it a relatively short time and perhaps see what you believe to be 12.6 volts or see full on the idiot lights. The final determination will be to use a hydrometer and look for a specific gravity of about 1.265 or above.
You dont need to use a hydrometer all the time but when a battery is sucked dead I always do so that I know it's all the way up. From there you just need to stay above 12 volts and do regular charges.
The cheapest thing for you to do is educate yourself quickly to 12 volt battery and RV use. People blow through batteries blaming brands and battery styles only to end up with another ruined battery from under charging. RV's are basically designed to be plugged in all the time. When you unplug that cord the whole energy management program becomes you. From getting power from your tow vehicle connection or plugging in at the storage place or running a generator or sitting in the desert on solar for months it all becomes you. It's completely different than walking in the door and flipping on a switch. It all falls on us. We become Pacific power or Detroit Edison.
There is endless reading material in here and it may seem confusing or overwhelming at first but it will come to you. In the end you will find it was easy if those basic things are adhered to.
44,056 PostsLatest Activity: Jan 12, 2020
