jeffreyduncan's avatar
Sep 15, 2015
Battery Charging and Isolation
Hi there.
I have a brand new 2016 Arctic Fox 811S on my 2015 Silverado 3500HD. The truck has two batteries and two alternators (Duramax Diesel) and the camper has a pair of group 27 batteries with a marine on/off switch. My question is: When the camper is plugged into the 7-pin harness, is there any isolation between the two camper batteries and the battery bank in the truck, or will I need to install a charge relay or isolator? If I need a charge relay, I'll probably use the the Blue Seas ACR, which I installed in my boat to separate battery banks, and it works perfectly.
I'm curious how I would wire it though. I assume the 7-pin harness has a charge wire present, which possibly connects to my converter, or direct to the battery bank? I'm pretty handy with 12V, but this is my first truck camper. Any insight would be appreciated.
Thanks in advance!
