Bedlam
Sep 15, 2015Moderator
Only Fords have isolation between truck and 7-pin plug. You will need to use an isolator or constant duty solenoid on other brands. If you want better vehicle charging capability, consider running a dedicated charge line to the camper with a heavier gauge than what is used in the 7-pin - Lance is the only one that normally does this on their unique connector, but it can be done with an Anderson connector between camper and truck.
44,071 PostsLatest Activity: Aug 16, 2026
