trvsdad1
Oct 21, 2013Explorer
Battery Charging Question!
Calling all you brainiac's. I have a charging, well actually a couple of battery charging questions for you to tackle. In my Alpenlite I have two deep cycle batteries. I can charge them in the following ways,1. with camper power switch off and unplugged from shore power source they charge through the F350 alternator while truck engine is running (power switch in camper must be off). 2. Plugged into shore power source with camper power on or off they charge.This leads me to believe that my "inverter" is on all the time whether the camper power switch is on or off. 3.Start my generator, it charges the batteries whether the camper power switch is on or off, (again I'm thinking my inverter is not off with camper power switch). We ran the batteries down at the Grand Canyon this past weekend. Had to start truck to juice them up enough start generator. Was the generator charging the batteries through the inverter or directly? (I may have answered my own question, because the generator puts out AC current to run a/c, microwave, can't charge 12 volts batteries with 120volts). So does my inverter always draw some level of current regardless of camper power switch being on or off? I've been thinking that off meant off, but please set me straight. Second question, how long should I run the generator to charge the batteries back up to full charge. Campground rules limited me to two hours in the morning and two in the evening. I don't think that's nearly enough, please set me straight. As a foot note I do have a solar panel to maintain a full charge but "DOES NOT" charge a depleted battery, only maintains a full charge. Thanks for reading and for your answers!
