hawkeye-08
Apr 08, 2015Explorer III
If your trailer does not have a disconnect switch then either add one or disconnect negative cable to stop drain and use one of the many solar chargers to keep topped off.. it is a pain to install and remove batteries every time you want to go out, so I would avoid that if possible. If you are not able to get solar charger, then at least disconnect batteries when not in use to avoid the discharging from the trailer...
44,056 PostsLatest Activity: Nov 19, 2013
