sign_man's avatar
sign_man
battery charging
When I first fire up my Honda Genny I can hear the converter turn on. once I know longer hear it does that mean the batteries are charged
  • do you have a hydrometer to check the battery properly?.. All the stuff with voltage, amps and charge time are not accurate way to determine is the battery is properly charged or not.
    https://handybobsolar.wordpress.com/the-rv-battery-charging-puzzle-2/
    read this to find out a lot more about batteries, charging and generators and solar.
  • No, the converter is silent, you are probably just hearing the cooling fan in the converter which is thermostatically controlled.
  • smkettner wrote:
    No.
    As the battery gets to 14.2+ volts, charge for an additional 60 minutes. This gets you to about 90%. 100% will take an additional 4 to 8 hours.
    If you have a fixed voltage converter you are slow charging at about 13.6 volts and you need 2 to 8 hours to get to 90%.
    thanks for the info
  • No.
  • Maybe. What make converter is it? What's the battery voltage when the fan quits?
