Cravenj18's avatar
Cravenj18
Battery connection
Hi getting into camping this year. Hooking up battery and their are 4 wires. Red and black in the same conduit. And two different shades of white in another conduit. Camper is a 93 salem by cobra. Im assuming red is positive whites are negative. Should both wires be hooked up to their respectice sides? Why is their 2 on each side? Any answers would be great
  • jwandvassie wrote:
    Connect the black to negative and red to positive.
    Use an ohmmeter to determine which of the white wires is connected to the chassis. (One lead on a non-painted nor rusty part of the frame and the other on the wires.) The one with near zero ohms should be connected to the negative terminal and the other to the positive.
    Noooo , not always on campers. Things can get weird and people can have messed with stuff.
    I wouldn't' hook up anything until you do some checking !!!!!
  • Connect the black to negative and red to positive.
  • Follow the wires to see which ones are grounded to the frame, that would be negative, never depend on colors. As far as the extra set, perhaps a power jack and/or the breakaway switch for the brakes, again follow the wires.
