esox07
Aug 14, 2014Explorer
Battery Cut Off Switch
Hi, I have either a bad battery or a drain on my system.  My battery is only lasting a couple weeks between uses and I cannot find any unusual system that would be causing it.  Regardless if it is the battery or a system drain, I would like to install a battery cutoff to isolate the battery when not in use.
First of all, would it be OK to install it outside of any protection since I have a TT and the battery is on the trailer tongue inside of a battery box. I was thinking I would just add it inline outside of the battery box before it enters the trailer. Also, which lead would the cut off switch be installed on, the Negative or Positive lead? Any suggestions on a cut off switch? I don't need anything fancy, just one that is dependable and has On/Off.
Thanks for any advice,
Bruce
Bruce
