sd75macExplorerApr 24, 2015Battery DisconnectWhat's the opinions on which battery terminal to connect a disconnect switch, positive or negative? Thanks,
PapaNIes60ExplorerApr 24, 2015As far as I know you should always hook up the switch to disconnect the positive.
Related ContentBattery disconnectBattery Disconnect ConfusionRemote battery disconnectHouse Battery Disconnect Not WorkingDisconnect batteries?
